Author Topic: XBox Music Style  (Read 79732 times)
Working fine for me after editing those. This is what I get:
BTW the button is a little out of the panels.
Another thing is that you won't need <allowPinning="true"> attribute for each of those six overlays not to display a close button over the icons.
endeavour1934
Ok, I found the problem: If the overlays have "allowpinning=true", then the floating panels don't show the close button. If it's set to false, they appear.
But, if the overlays don't have the "allowpinning=true" the plugin doesn't remember the last overlay used upon opening/closing Theater Mode.
[BTW, I fixed the closing buttons positioning, even if now they aren't showing up]
Last Edit: February 16, 2014, 03:10:09 AM by endeavour1934
Probably removing the attribute has the same effect as setting them to false. IMO not remembering the last overlay is not a big deal as compared to having the close button interfering with a few buttons at the top.
endeavour1934
? On my computer nothing shows up at the top near the other buttons. I guess that's part of the same problem, so for now it's a bit difficult for me to fix that - unless I do what you said before and set all overlays to false.
You don't see this?
If you want it to remember last overlay, then I guess there's no solution currently.
endeavour1934
You don't see this?
No, as it is now, there isn't a single 'close button' showing up on the entire config.  ???
EDIT: Nevermind, I think I found a solution to all the problems. Could you download the config again and try?
Last Edit: February 16, 2014, 04:26:16 AM by endeavour1934
there is a bug (my fault) where once you open the Now Playing list, even when closed it still shows the mouse click icon. Thats fixed for the next plugin update.
However, there is one behavior you might consider changing - if you hover the mouse to the right margin of where the lyrics would display it pops up the lyrics. If thats not what you intended you can disable that using
<autoHide name="#SidebarArtist"  ... disableHotPoint="true" />
<autoHide name="#SidebarLyrics"  ... disableHotPoint="true" />
<autoHide name="#SidebarPlaylist"  ... disableHotPoint="true" />
endeavour1934
Working great!
All done, zips updated
Thanks to both for your help  :D
this version includes the fix above and also closes any overlapping floating auto-hide panels, so you shouldnt need the 2nd variation any more:
http://musicbee.niblseed.com/V2_3/MusicBee_Exe_Patched.zip
silvestreccf
Nice :D
I've made a final update to darken the close buttons.
https://dl.dropboxusercontent.com/u/10773406/xb2.zip
Very Very good!! a very perfect and similar to Zune, that is the most Beautifull.
You could put a auto-hide popup with the track list.
(issue) The little button to activate Lyrics its not working
It is possible to make a skim to BeeMusicPlayer similar to this theathermode? so Metro!! so clean!
silvestreccf
You make something better than original, very similar to powerfull Zune player interface,
But the Theathrermode  need a volume control and a tracklist, is ti this possible?
A back button also would be espetacular...
it is possible make a clean Skim for the main player, with this collor and interface?
Nice Work.
endeavour1934
I'm not trying to replicate Zune exactly. Maybe for a Zune Style Theater Mode, or future layout changes. For now I'll leave it as it is.
BTW, there is a tracklist, just to the left of the three main player buttons.
