Author Topic: [solved] Integrated file explorer should show albums in subfolders  (Read 3069 times)
Legion
Hello there,
I just discovered following problem: when I use MusicBee's integrated file explorer, it shows my only a music album, when I select the album folder.
For example:
When I select in the file explorer following directory "..\Music\2012\02\Abbey_ov_Thelema-A_Fragment_ov_the_Great_Work", then MusicBee shows the album in the main panel. So far, so good.
But when I select "..\Music\2012", it shows me only an empty main panel. Would be could, if MusicBee would show me ALL albums within the selected directory.
I hope, you understand, what I am trying to tell you ;).
Kind regards,
Legion
Last Edit: September 20, 2012, 05:28:40 PM by Legion
Legion
Argh. Just found this "missing" option. How embarrassing.  :D
Right-click is your friend  :D.
Solution:
1. right-click into file-explorer area
2. Manage Folders -> Include Files from sub-folders (activate)
Sorry, my bad.  :-\
Regards,
Legion
Gordito
Thank you!! Glad I did a forum search before requesting this as wishlist. So happy right now!!!
