Author Topic: Scrambled device name --> sync failed  (Read 6207 times)
geldi2002
Hi Guys
I use MB with a Cowon J3 player in MTP mode. Often when i sync my device, at some point the sync goes wrong and the name of the internal storage of the J3 is scrambled (which is also the reason why the sync goes wrong, it cant find the path specified in the settings and copying thus fails). The only way to fix it that i found up to now is to unplug the J3 and reconnect - the internal storage has again its normal name and syncing can be tried again. Does this happen to anyone else? Is there a way to avoid it?
Cheers
Felix
geldi2002
I am using Qtscrobbler too to sync my last.fm, usually before syncing the device with musicbee. could it be that there is a connection between the two things?
