Author Topic: MetroColours (Light) BETA  (Read 15545 times)
lnminente
Light beta version in cyan, it could have some inconsistencies as i started from the dark skin, also the bitmaps are for the dark version yet.
Download:  http://www.mediafire.com/?a0786bsakzan9eo
(Highlighted colours easily modifiable in the variables of the xml)
Last Edit: September 29, 2012, 10:27:09 PM by lnminente
beeing good
Very nice lnminente, thank you! I haven't tested it much but seems to work well so far.
antiPOP
I like a lot, really good job, btw I found a bug, take look at the picture
the active tab is not readable. i think gray scrollbars like on the picture will better fit your skin.
lnminente
antiPOP
Thanks! I've modified it, for my own taste, now it is really light hehe and better fit windows 8 default skin.
btw. it is possible to get rid these ugly black frames?
lnminente
Can you send me or share here your mod? I'm precisely looking for the lightest effect possible
The buttons with "..." i think they were sharing the same value with another elements, will try it later.
lnminente
For the buttons border search for this element and replace it for the following line:
<element id="Controls.DropdownButton.Default" bg="Ground+4" bg2="Ground" fg="Default" bdr="Ground-2" />
Add this  <element id="MenuButton.Border" bg="Ground-2" /> for the menu button border.
I like that flatter look using white ground+ variables. I will flat the main gui in a future version :)
antiPOP
I have the another question
how can I change color of selection? I want to make it a bit brighter.
lnminente
For every single element in this skin or any other: The dummy skin, it worths spending some minutes ;) http://getmusicbee.com/forum/index.php?topic=6113.msg37217;topicseen#new
lnminente
Sorry i'm not updating here, just noticed this is my skin most downloaded but with the casualty i never finished it and now is abbandoned. So this is just for telling the community might be interested in having it working well, so if anyone is interested feel fully free to publish a mod or update it. Thanks!
Statistics here: http://getmusicbee.com/forum/index.php?topic=9543.new#new
Last Edit: April 28, 2013, 09:31:21 AM by lnminente
