So again until the merge, I got no notifications. I was pretty sure I had them activated they worked for a while and then stopped again.
Sorry, I am not actively checking the forum and tried to rely on the notifications.
Hey Keepsy.
I am pretty sure that the radio stations are supported by the plugin but not implemented in the app, at least not on the release. Unfortunately, since summer I am busy with another open source project and I haven't been able to continue my rewrite efforts with the remote. I still need some integrations with the notification system after the rewrite and also fixing the library functionality before having a working alpha out.
Hey Fcp, Are you using the Windows Store version? or the installer of MusicBee?
If you use the store version, the installation process is slightly different. You have to download a zip from the releases page on github and then you have to go MusicBee's settings and install the plugin using the zip. Unfortunately the installer won't work with this version.
ms.glug the same as above
Babydoll32 there is a huge problem with large libraries, that is also one of the reasons for the lack of updates since 2017. I started rewriting the plugin, then I started rewriting the app, and then things happened and throw my plans completely off.
dandepeched good to know, if you need any help with the plugin or the protocol please feel free to drop me an e-mail. I try to answer on time
I will try to check the app if I find some less busy moment.
By the way, the most important thing to know, if people have connectivity issues, windows tend to reset the firewall rules once in a while resulting into the app not being able to connect to the plugin. Usually settings the firewall exclusion again seems to solve the problem. This is by far the most common connectivity issue.
