Author Topic: Black & White skins  (Read 17646 times)
jistme
(and greys...)
http://www.mediafire.com/?58999o1u3y3e1
Black & White:
edit 09-02-2013:
Black & White is finished, the others are not quite ready and still need some work.
download 'Black & White'
edit: Discontinued, the links will probably be or become dead.
Last Edit: June 22, 2013, 09:41:48 AM by jistme
Underneath
Very good job! Would be great if you would use a bit more full black instead of the grey at times so it could look more balanced.
jistme
Thnx,
A more extreme 'Black & White' was added to the less contrastfull 'Blackish & Whitish'.
Let me know if you have suggestions to improve.
(I just can't get rid of the green 'ticks' in Preferences panel)
Last Edit: July 04, 2012, 05:46:50 PM by jistme
Rotem K.
Check image element "CheckTick".
Visit the skinning guide regarding image elements if you need any help with those kind of elements.
jistme
Maybe I could give it a shot to learn using those image elements, but both your link to that base64 tool, and the links to the checkticks images are dead.
Rotem K.
Gosh, those links, can't they stay online for more than a few days?
http://minus.com/mblHbmv20y - both base64 and the checkboxes images.
Last Edit: July 04, 2012, 07:49:01 PM by Rotem K.
wow23
jistme
Updated, three variations:
- Black & White
- Black & White gradient (best in flat-layout)
- Blackish & Whitish
(edit: small improvements)
Last Edit: July 06, 2012, 11:07:34 AM by jistme
jistme
Finalised 'Black & White'
(the other two are not really complete yet)
jistme
Updated 'Black & White'.
- Added customized colors for the wave bar. (v. 2.1.4702 or higher required)
- Several small improvements
Last Edit: November 17, 2012, 08:44:55 AM by jistme
jistme
Updated Black & White
(support for new spectrum visualizer in Now Playing panel)
