i have changed it so an existing Now Playing list tab will be re-used and if none, a new tab opened
Could this be made an optional setting please?
In the latest beta, when I double-click on a song that isn't in my library, MusicBee opens, then opens a new tab and plays the song. If MusicBee is already open, if I double-click on a song that isn't in my library, it opens a new tab and then plays it.
I prefer the old behaviour of it not opening a new tab, so it just plays the song. I don't use tabs at all, so I'd rather it not do this. If you can add a setting to toggle it on/off, cool.
i want to avoid adding options as much as possible to reduce the complexity.
What i have done to try and get a compromise is:
- if there is a tab open with the Now Playing list MB will use that tab (that is already the case with the recent behavior)
- otherwise, if the current tab is locked then a new tab is opened with the Now Playing list
- otherwise, it will navigate to the Now Playing list in the current tab (that was the old behavior) - you can click the back button to get back to where it was before
