Hi, thanks for the critics.
In my opinion you've overdone it by packing too many different views and variations in one single theater mode. Because of the many menu items, they are pretty close to each other now (1920x1080). So, it's difficult to hit the desired view at all... As a suggestion I'd create a separate "Grebs Font Theater" (or whichever name...) which could contain all entries mainly differ by the specific fonts (menus between "Folkie" up to "Formal [Central]"). An additional advantage would be, that the remaining final theater mode probably wouldn't compulsively need any additional fonts [...] After that you could come back to the "one line - one menu point" which is (in my eyes) better readable
Mmm... I disagree with that. From my point of view, the compressed menu looks better. But this is a matter of taste. Not a big problem to recover the old menu, to increase the font size and to add them as a couple of additional TheaterModes, one with the additional fonts and other without. Not a big deal. The zip file doens't have necessarily to contain only one Theater Mode.
Anyway, Steven sent me a message saying that he is thinking in developping -in a couple of weeks- a 'Menu system' for the Theater Mode, so the different layouts could be selected in a (I suppose) contextual menu that appears, for example, when you click on the screen. I'm gonna wait in case he does that. That case, I'd convert the TheaterMode to the new menu system (that -I suppose- would look like the normal contextual menu according the selected skin). In case he doesn't find the time or is more complex than he thought, so finally MB is not updated that way, I'd create a new Theater Mode using your suggestions.
Because "Bar and List of Songs" shows no list of songs, if "[+ Cover]", "[+ Bio]" or "[+ Lyrics]" was selected afterwards, these additions should be under a separate menu
I don't understand that. 'Bar and List of Songs' shows a list of songs. But anyway, if the Menu update comes to light, they will be different options in a normal menu. If it doesn't, I will recover the old menu to make to alternative TheaterMode, where they were separate options.
I'd remove the "[+ TW]" variations, because the difference seems to be not really huge (by the way, what does "TW" mean?)
'TW' means Typewriter. If you install the extra fonts, you'll see the difference. The left option looks like a handwritten piece of paper, while the 'TW' one looks like the same piece of paper, but with the title/lyrics and so, written using a typewritter.
- "Simetric" should be spelled "symmetric"
Thanks, I'll fix it.
