I could not figure out that title length limitation in the older setup, and there were other inconsistencies that I could not figure out, , so I simply re-did the previous pattern under Steven's new baseline... That red area in the example above shows how he controls it (It can be changed to blend in as if it is not even there).... the upnext is limited to that red area and then the title text is limited to being left of the progressbar.
<element type="Field" id="Title" xAnchor="Picture.Right" x="15" yAnchor="Panel.Bottom" y="-88" widthDock="X:ProgressPosition.Left" width="-10" font="Arial" style="Bold" size="13" fg="250,250,250" ></element>
So this limits the title text to the right: widthDock="X:ProgressPosition.Left" width="-10"
This setup has enablescaling set to true, which the others did not.
Anyway, if you want an Identical 'looking' copy of what I did before, I can do that (but i think that you can do that too). Just make sure there are no bugs in what I have up already and I could then build on that (I made some changes locally, but feel no need to share them at this stage). I feel I am pretty much finished and that I have learned what I wanted to. I hope you feel the same.
I learned that each item has a point of relation, and the more stable the points are, the more stable the item will be.
You have really helped me tremendously and i appreciate it. I also appreciate Steven's idea for us to do this in a thread like this. I am more than willing to accommodate you with any further efforts you make at learning this stuff. It was fun!
