For all of you who use Notepad++ to edit and amend the MusicBee LNG file for your translations, I scribbled down an userDefineLang code that highlights the different parts of the LNG file in different colours. That has since been amended and hugely improved by
Roadrunner (vielen Danke). You can download it from Imagenetz.de or, if that doesn't work, my Mediafire account. Both links are found at the bottom of this post. Note that it can only be used in full with Notepad++ version 6.2 or later.
Roadrunner's markup looks like this with the Swedish LNG file (Roadrunner's more elaborate screenshot in English is found in a post further down at this page):
The markup highlighting code may be altered in whatever way you see fit, and if you like your "design" better than mine (you can find it in
this MediaFire folder) or Roadrunner's, just post it here for others to benefit from.
Cheers,
Lakrits---
This is how you use it:1. Download the ZIP file via the link below (under "Download the ZIP file") and unpack the file
userDefineLang_MusicBeeLNG.xmlIf you already have an userDefineLang.xml file (in
C:\Program Files\Notepad++ or
C:\Users\[username]\AppData\Roaming\Notepad++):
2. Open the files
userDefineLang_MusicBeeLNG.xml and
userDefineLang.xml in Notepad++
3. Copy everything from "<UserLang …" to "</UserLang>" (i.e. all except the "<NotepadPlus>" tags)
4. Paste it into your
5. Save the
userDefineLang.xml file to
C:\Users\[username]\AppData\Roaming\Notepad++ (or your equivalent folder)
If you don't have an userDefineLang.xml file:
2. Rename the file
userDefineLang_MusicBeeLNG.xml to
userDefineLang.xml (remove the "_MusicBeeLNG" part)
3. Save the
N.B.! You must restart Notepad++ to use (and see) the new language option, you find it at the bottom of the Language menu.
Download the ZIP file:From Roadrunner: | | | Imagenetz.de | | | (for Notepad++ 6.2 and above) |
Alternative link: | | | Mediafire | | | (for Notepad++ 6.2 and above) |
(If you find the download page at Imagenetz.de a jumble of strange words, just ignore all German words and click on the English text "File download!". Apparently, it's a button
Notepad++:You will need the text editor Notepad++ in order to use this markup highlighting code.
Download
Notepad++.
About the Notepad++ user defined language:Study the
UDL 2.0 online documentation.
Spikar'u'nte inglish? Föredrar du helt enkelt svenska?
Du hittar svenska språkfiler i
den här tråden.
Non loqueris lingua Anglorum? Grammaticus fastuosus Oxbrigiae es?
In
hoc filum documenta linguae Latinae nancisceris.
