Author Topic: Video Support  (Read 100088 times)
Antineutrino
Is it possible to watch VOB files?
When I'm trying to start a video, MusciBee says that for VOB files a codec is needed. I have K-Lite installed, but this doesn't work.
masahal08
I?have installed video codecs and can play video on main window.
However, I use multi-display, and can't play video when moving MusicBee window to second or third display.
On other video players such as vlc, video can be played on second or third display.
I tried other codec such as shark007 but can't play in the same way.
In addition, when video play is finished, the message "the file is not a valid audio file and cannot be played musicbee" is shown.
OS: Windows 7 Home Edition Service Pack 1 64bit
i'm not doing anything with the Video plugin in musicbee until i see what the plugin developer delivers for the next version, so for now its not being supported
stefan
 :( I am trying out MusicBee, currently using Winamp.
I am trying to get the video plugin to work but on both my destop and netbook I get stuck.
When I try to enable video support in preferences plugins I get the following message:
"the video support plugin could not be loaded - locate bass_dshow.net.dll in Windows Explorer, right click / Properties / Unblock.
I followed these instructions but still get the dialogue in MusicBee
VX
It seems that Video Plugin can cause bugs:
http://getmusicbee.com/forum/index.php?topic=9265.msg54383#msg54383
IMHO, using LAV Filters instead would be a better choice:
More info:
http://forum.doom9.org/showthread.php?s=79d888ba1e33e97709a60123a88a032d&t=156191
Despite advantages mentioned in reply no. 14 in this topic it would improve CD-Ripper and Converter experience.
LAV codec can be used to convert a mp4 file to mp3 for example.
Any chance to consider implementing LAV Codecs for MusicBee 2.1 final  ???
Space Octopus
  • Teach a Man To Reason, He'll Think For a Lifetime
So is it still available for those of us who do know codec packs are actually good & aren't crazy? I would rather like to at least be able to try using it even if there might be an issue, but it looks like you removed the link. :(
Seems like it works for enough people & I've always had K-lite, which I guess means a better chance of it working for me, so if it's not too much to ask, could I be pointed toward where it might be or something?  ^_^
Make it so, number one.
unfortunately the guy who developed the bass video plugin that my plugin is based from does not appear to be spending time to support it, i feel it wasnt fully ready, and also i cant justify the time needed to support it so i am doubtful it will go anywhere.
