Author Topic: Filters with fixed layouts  (Read 9036 times)
nycebo
The advanced idea:
Being able to save the view and how columns are set up into presets. Somewhere there can then be  a preset-menu where one can save and load different, maybe even named, setups. If someone changes some columns in a playlist where a preset was loaded, the preset wont change, think of it as making "an exception to the exception". However if someone saves some column setting to an already existing preset, every playlist that have loaded this preset will change accordingly.
Just some thoughts. :)
I really like that idea of having views/columns saved as presets.  Brilliant. :)
jistme
Can be handy, sometimes you want to go into 'the depth', sometimes not.
Also e.g pop music might require different columns than classical music.
Last Edit: April 12, 2012, 12:02:13 AM by jistme
