Author Topic: Album & Track Star Rating Element ID's  (Read 7912 times)
Joergermeister
  • I used to jog...
Hi there,
i've searched the forum but did not find any answer. If this is not the correct  forum thread, admins please move (help).
I'm actually looking for the Album & Track Star Element IDs in the Skin .xml files. It seems most of the skins are carrying the music bee default, which does not have a great contrast beeing light grey and dark grey.
https://www.dropbox.com/s/uogzit0qqeyyl5a/JL-10.02.2012-00.png
So what do I need to add to the .xml file to adress these star ratings.
thanks in advance
Rotem K.
You're looking for element "Panel.StarRating.Default".
FG controls the highlighted/selected stars color, FG2 controls the lowlight/background stars.
Best of luck,
Rotem
Joergermeister
  • I used to jog...
