Author Topic: Artwork Folder Visualiser  (Read 3909 times)
larryfine
I don't know but, is it possible adding an option at Artist Pictures Visualiser to scan folders with artwork and play like slideshow in the Visualiser Tab?
greenday1987
  • Long live OiNK!
That would actually be pretty cool, all the folder.jpg etc
RIP OiNK
cartman005
This sounds like this visualizer that I used to use back with iTunes. It was pretty sweet and worked on the same concept. Maybe there is something like this for WinAmp that can be used as a plugin?
I did a quick search but don't see anything obvious.
larryfine
You're right, cartman005.  My thought was a plugin like foobar's albumart (foo_albumart) which displays a slideshow from any folder defined by user.
Another choice could be an extension/addon for xulrunner.
Last Edit: January 18, 2012, 02:23:53 PM by larryfine
sturmgas
Mmm, would like that as well. Niciest thing out there is the zune Now playing screen.
