Author Topic: Reorganize music  (Read 4119 times)
lsueirasb
in a drive other than c:
If possible....
Regards.
you mean on your portable device or usb stick?
As long as its a USB stick you are talking about it should be OK to do that. MTP devices i wouldnt be comfortable to that as its quite different.
lsueirasb
Yes, i got a usb hard drive than i only plug in when i go to listen music.
Regards.
hi,
i was just looking at this - you should be able to re-organise files on a USB device as i just did it myself.
The restriction i have in place is the same as previously mentioned - it wont let you re-organise to a different drive. What you probably need to do is simply change the 'move files to folder' to refer to the drive and folder on the USB device - by default its set to the folder the music library is installed which is usually the C: drive
lsueirasb
I tryed and works perfect!
Thanks Steven.
