Author Topic: ABX Double Blind Listening Test  (Read 3278 times)
BigHam1
Currently I use a utility in Foobar to do double blind listening tests (to compare, for example, standard vs remastered tracks):
Foobar ABX Comparator
http://www.foobar2000.org/components/view/foo_abx
Would love to see this functionality in MusicBee!
Could even improve on it, to automatically do a replaygain analysis before setting up the test...
Anti
Sounds like the job of a plugin rather than an inclusion in the main player.
Doesn't your mixing/mastering software have the ability to A/B test?
kstuart
In typical foobar fashion, there is absolutely nothing that tells you what the component actually does. ;)
