Author Topic: Scrolling lyrics during visualization  (Read 5126 times)
abhinavsays42
if the lyrics is synchronized, is it possible to have scrolling lyrics during visualization?
P.S. this can be done using minilyrics running in parallel (activating its floating mode and keeping always on top), but i'd rather have just one application (MB) open at a time.
Last Edit: December 20, 2011, 04:25:52 PM by abhinavsays42
i've added an option to the now playing layout settings where you can set lyrics to be displayed against a transparent background when floating (floating lyrics is already supported). However its doesnt really work well unless you have the floating lyrics window against a neutral background and to work better would require some fancy work with the fonts to get a glowing effect around each letter. I'll leave the option in as it might be useful for some people as is.
I've also added a setting to override the colour of the highlighted text for synchronised lyrics
abhinavsays42
sounds good already.    :D
Any way to download synchronized lyrics without using minilyric helper?
Last Edit: December 22, 2011, 12:16:01 PM by abhinavsays42
ma_t14
Nope... Unless you know another source where they maintain a database of synced lyrics everybody would be grateful. MiniLyrics seems like the only one  :-\
abhinavsays42
Dont know any other source   >:(
but isnt it great we have minilyric helper...  ;D
there is - see the plugins section
ma_t14
Wait  :o
Does that mean there are other sources for synchronised lyrics except MiniLyrics?? I know about the lyrics plugin but I thought its only about static lyric  :-\
