Author Topic: Cataloging and playing DSD files  (Read 74640 times)
emmecì
3.2.6715
but that is not the only weird things that happens. For example, with my dac there is no way i can use wasapi until i skip time with the playing seekbar, while on other programs that it wont happen. Then you'll say to use other programs. I'm sorry but to me, musicbee is the best for organizing music, its immense configuration, leaves the other far away...
EDIT: crossfading removed, for the moment seems to work
Last Edit: May 24, 2018, 06:14:47 PM by mirkocosta
rupert
Hi I'm loving the organisation of this player. I have tried installing the beta update and selected ASIO then when i choose DSD native it tells me 'The ASIO device does not seem to support raw DSD data output". When I select DOP it plays OK. In Foobar I can play DSD and PCM and upsample them to 11.2Mhz through my ASIO driver and/or DSD: WASAPI plugin. Would love to see something similar here.
lux1o
my dac ONLY support DSD data as PCM (DOP) -
but musicbee some time send noise when i configure output DSD data as PCM (DOP)
other times works well recogniced but when a song finish musicbee crash and close
i configure musicbee dsd raw and the dac display
"DSD 3.87mhg etc
something ia wrong in musicbee
i test my foobar2k and it play ok
its probably best you use foobar for your requirements or use "Convert to PCM" in the ASIO settings
lux1o
Just two days ago musicbee works properly
You must've done -something- that caused the change. In any event, Steven has given you two suggestions to help with the issue.
lux1o
yes i done something. i update musicbee to the last version
MagSirius
  • Salut de Québec
DSD files play easily on my Topping DX3 pro usb DAC. I choose Asio + topping USB , stream raw dsd and voila, it's written 2.82 dsd on the dac, and it sound like it .
Last Edit: August 14, 2019, 10:37:01 PM by MagSirius
Yiri
I listen to streaming radio in DSD512 format.
DSD512 files are easy to play on my Topping DX3 pro usb DAC. I choose ASIO + foo_dsd_asio.
(ASIOProxyInstall-0.9.4.exe)
Asio Proxy 0.9.4
Audio Device: Topping USB Audio Device
Inpput_|__Output_|_Converter _|_ Sample $ Hold_|_DSD Mode
44100_|_DSD512_|_SDM typeD_|__NOTE_______|___DSD
Yiri
Last Edit: March 14, 2020, 10:22:53 AM by Yiri
mikemcsw
Asio Proxy 0.9.4
Yiri
I am confused...are you saying you are using a foobar plugin in musicbee or you are using foobar?
