Author Topic: Lyrics Plugin  (Read 160694 times)
There is a free program called take ownership, after installing it right click on the music bee program files folder and select take ownership.  Then unblock the DLL. Worked for me with the mini lyrics plugin
Yup, that did the trick.  Thanks!
Iasc
SilenceKidt
I went to Tags (2) in preferences, chose what sites I want the lyrics to come from, and checked "auto-retrieve missing lyrics for this track." What else am I supposed to do because it's not using those sites as lyric sources.
yakamoneye
I have the same problem, can not have the words or sites for theater mode since I'm running Windows 8 pro 64. Unless I keep the basic version 2.0 and again the words, I still have 4 sites only theater mode works (but I know that it is not in this post that I have to ask)
ok , i find the solution
Last Edit: December 30, 2012, 10:41:33 PM by yakamoneye
DPeichl
I installed the plugin a few days ago, and I've noticed that it sometimes finds the wrong lyrics.
For example: today, I was playing "Can you read my mind" by The Killers and the lyrics that came back were for a song with the same name by Brian McKnight.  Since "Brian McKnight" appears nowhere in the tags or the file name, I assumed that meant the plugin doesn't use the name of the artist (or album) in the search terms, and just returns the first one it finds by the name of the song alone.
Also, it seems to have a problem with non-standard characters, such as the backwards R in Ko?n.  I recently changed it to the backwards R because Music Bee was telling me to "keep my tags clean" when attempting to get the cover art, but now that I've done that, the plugin can't find any lyrics for Ko?n because the web pages are expecting an English "R."
I considered looking at the source code myself, but the link is broken.
puppyandres
Hey guys, who created this plugin "Steve" sent me http://www.mediafire.com/?ia8ezlbso6t78o8 , that is the plugin's code but i have no idea about Visual basic, i was trying to add more websites, but as u would know, i failed...i  wanted to add 2 websites (one for spanish songs and one for chinese songs)..so if anyone would do this it would be great to improve this plugin...
http://pinyin.azlyricdb.com/ for chinese lyrics
http://www.musica.com/ for spanish lyrics
nogoya2002
puppyandres
dont work, please help me
i need musica.com
over 750.000 lyrics in spanish too in english
thanks :P
AggronAmarth
Awesome plugin, MB's default sources weren't picking up most of my lyrics, but this is doing well so far. Good work \m/
@DPeichl: Try going into 'Tags (2)' and checking 'ignore diacritic marks when searching' perhaps? It's worth a shot, at least.
maximus_orfeu
please add
http://letras.mus.br/
in  portuguese brazilian
thanks a lot!!!!!
romanos
Could you please share the c# source code as well?
I'd like to take a look at it.. Thank you!
here is the c# source - as mentioned this plugin was written in VB.net and this is just a translation. I have just added a couple of fixes that were made to the original VB version:
http://www.mediafire.com/?pwnqe5ncph813wu
this is the VB version if you need to do a comparison:
http://www.mediafire.com/?p98ck1nul3yy9pa
jistme
Where can the most recent net4 version of this plugin be downloaded?
The start post was last updated September 7th, and the last post on an updated version I can find (Feb 20th?) has a deceased mediafire link.
http://getmusicbee.com/forum/index.php?topic=4751.msg32348#msg32348
