Author Topic: There a simple way to view the leaflet , back cover without switching primary?  (Read 7210 times)
donprime
Example: for a single CD I scan the CD itself, leaflet, Front and Back Cover. Then tag all 3 or 4 pictures to the Album. but you can only choose 1 as primary which is fine. But there is no way that i found to switch between the different covers unless you go to edit and switch the primary.  Anyone know of a simple way that i missed?
ma_t14
No I don't think this is currently possible but it seems like a really nice idea
Antonski
Maybe cycling through all stored images with delay that can be defined (0 = no cycling)?
donprime
Well hate to say it, but in MediaMonkey all you have to do is right click the album to choose the different images you tagged.
Blinghound
Maybe there should be a way to cycle through each image tagged to a song where the artwork is displayed under the 'Playing Files/Selected Files', or when the artwork is displayed in its own window full size (upon double-clicking).
i've just done a simple right click/ select the image from the context menu
http://www.mediafire.com/?2dcgfchpu7zq617
Last Edit: October 13, 2011, 10:21:46 PM by Steven
cartman005
donprime
wow, thanks Steven for adding it., Like cartman said, still doesn't show the new image when you select it . But your awesome so you will fix it.
Last Edit: October 14, 2011, 02:47:45 AM by donprime
greenday1987
  • Long live OiNK!
Sorry for going off topic:-
What's the best way to change an artist picture to another one also saved as an 'artist' image? I always find that if I change the image by changing the 'primary picture' then the album art for each album gets changed to said image too.
RIP OiNK
in the artwork layout, when grouped by artist, if you right click on the picture/Paste Artwork - it will replace the artist picture.
'primary picture' only relates to album artwork.
does this fix the problem (i couldnt reproduce the problem):
http://www.mediafire.com/?65m38natsgcuc89
greenday1987
  • Long live OiNK!
Yes, atleast for me :)
RIP OiNK
