Hi. I'm trying to configure MusicBee to send DoP to my DAC, from native DSF (DSD) music files (2L Records). Windows 10.
I tried Foobar2000 with the DSD plug-in and it works good. The DAC displays "DSD" received (1x, 2x, and 4x).
I tried JRiver with the DoP setting and it works good. The DAC displays "DSD" received (1x, 2x, and 4x).
With MusicBee the DSF file is converted to 88.2kHz PCM.
I read on a Google search that I need to manually configure MusicBee for
DoP output. Apparently this is found in the Preferences => Player => Audio Player and then selecting the CONFIGURE box. But the CONFIGURE box is not selectable. Dead click. On the DSP screen, nothing is selected (no EQ, no level shift, etc). I
can select ASIO and then CONFIGURE, but this DAC has no ASIO drivers. This DAC uses the audio drivers in Windows, only (WASAPI Exclusive).
Any ideas? (screenshot link below)
p.s., where do I find the revision/version level of the installed MusicBee build?
https://imgur.com/a/lLWKMJV
