Author Topic: Columns Browser & Window Resize Issue.  (Read 611 times)
eggbeater
Hello, I am new to MusicBee and I seem to have discovered a bug. I am on Windows 11 using Musicbee 3.6.9202 P.
When the columns browser is hidden via panel customization, changing between vertical to horizontal causes the entire Musicbee window to resize bigger!!
This happens in panel configuration, when a hidden columns browser is changed from vertical to horizontal. It also happens when switching between tabs in which one has columns browser as vertical and the other horizontal, but again only if one or both have hidden the Columns Browser via panel customization.
If the columns browser is not hidden in panel customization but is hidden via the configure layout menu the issue doesn't happen.
I don't know if its related but I do have dpi scaling in Windows 11 set to 150%.
I cant reproduce any issues. Can you send a link to the settings file (help/ support/ view settings)
Thanks for sending the settings. I can reproduce this and will look at it over the next few days
eggbeater
Thanks! That seems to fix it to some degree, but I was still able to cause it to resize.
I changed one tab like this
customize panel > uncheck "hide columns browser"
configure layout > column browser > horizontal
customize panel > check "hide columns browser"
Switching back to this tab from another tab with vertical columns browser will cause the window will resize.
i cant reproduce this. Is it resizing vertically or horizontally?
eggbeater
the window is resizing both vertically and horizontally.
