So I use primarily the Main Panel for my operations right now, and the "Column Browser" and "Files" more specifically, with just a bunch of fields in both. Pic for general reference, because the specifics aren't important.
Ok, so in the pic I selected "Akira Yamaoka & Mary", and let's say there were some albums there I wanted to choose, and then I realize that aha, actually, I also want to select ANOTHER artist to add to the mix ("Files Panel" in the "Main Panel"). Problem is, if I then go to the artist field left of the album and track column, then I suddenly lose the selection I already had. The same for whatever things I decided to choose, such as Rating, Tempo, etc (which is why I sometimes have opted to have some fields basically REPEATED in several columns, say one in the far left, and one toward the far end). So it's like the "workflow" for choosing tracks to "add" to the "Main Panel File Panel" is nested, flowcharty, linear, whereas I really would want it to just be less hierarchical, with more toggle options.
I tried using filters, but only one at a time would work, so I tried combining them, but it all just isn't working very smoothly as soon as I want to switch something up. I'm starting to think that mine is a question not of simple functionality, but of workflow, in that maybe I'm going about it wrong in trying to use just "one step" in my workflow, meaning choosing stuff at the "Column Browser" and "sending" them to the "Files Column", or that indeed one step would be enough, but would have to consist of some other function than these two column panels specifically. Maybe utilizing Auto-Playlists, Auto DJ, and Playlist Mixer functionality would help me, or some other thing yet? Having a couple of tabs for sure I can imagine could help out, but not quite sure not now, honestly. Still I can't seem to get out of my head that just being able to toggle certain things "on the fly" would help immensely.
Any ideas for me?
