Author Topic: Dragging duplicates from Playlist to Now playing or vice versa  (Read 674 times)
rkapuli
Thank you again for this great software. I don't know if this is a bug or some setting that I'm missing (i've gone through all the settings and can't find anything). I use MB to DJ tango music, and sometimes will drag whole sets of songs (some of which include 2 second spacers that are duplicate files). Previously there was no issue doing this with the previous versions I used. Currently running 3.6.9271 and it's not allowing me to move the files back and forth either from playlist to now playing, or in reverse. It drops all duplicates and I have to drag one by one to make it work. Previously I could drag all the files in one go. See the image attached.
rkapuli
Downloaded 3.6 in another computer and replicated the same behavior. Opened an older version 3.3.7242 P and I could transfer everything including the duplicated files. Can't tell if it's a difference between the Portable vs Full download or old vs new version.
There is absolutely no functional difference between the Installer and Portable versions (of the same version number.)
It's possible your issue is a bug in which case you'll have to wait for Steven to take a look at it. Or it's possible that functionality has been removed intentionally. Again, Steve would be able to clarify.
rkapuli
Thanks phred. Also noticed that if I select the files and right click "Queue last" it copies everything including the duplicated files. They seem to be missing only when dragging them.
