Musicbee fails intermittently with no message but the following in the system app log:
Faulting application name: MusicBee.exe, version: 3.6.9202.37404, time stamp: 0x67d1583e
Faulting module name: ntdll.dll, version: 10.0.26100.4061, time stamp: 0xb156cd48
Exception code: 0xc0000005
Fault offset: 0x000699b6
Faulting process id: 0x314C
Faulting application start time: 0x1DBD012DB793C65
Faulting application path: C:\Program Files (x86)\MusicBee\MusicBee.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Prior to Musicbee failing there is also a message from .net:
Application: MusicBee.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
at #=z6mlndMgzDgL1NzGg3nGaaoM=+#=zmzRuG69dGdfX.#=z5F_daLB0uJcGJz07L0ls2Un$mmF5(Int32, Int32, #=zDGUBaDMMVkTZ, Int64, Int64)
at #=z2x9GInrzZ_UAdiz4gax9oZE=+#=z3ShvXBCqRq$Z.#=zuVZxyHA=(Boolean)
at #=z2x9GInrzZ_UAdiz4gax9oZE=.#=zrss7M9LTNpgz(System.Object)
at System.Threading.ThreadHelper.ThreadStart_Context(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Threading.ThreadHelper.ThreadStart(System.Object)
I can restart quickly enough, but is a problem doing my radio show. The app just stall for half a second and then disappears with no interactive message. This seems to happen only once a week, or so.
Thanks for any help you can give.
