Author Topic: main progress bar as waveform error  (Read 1434 times)
IndigoFairyX
found a bug when the main progress is in wave form more, i can't click in the wave form to change the playing position as can when the seekbar is in the normal mode. nor can i right-click to access the context menu. i get a glitched tooltip flashing with the sink-times.
additionally i also have a waveform seek in the right column about the now playing list. i can seek through this one just fine.
currently on the newest MB version and win 11.
Since Steven is releasing patch updates every few days, it would be helpful to know exactly what version you're using.
Help > About
IndigoFairyX
I'm using my own skin that i wrote, thought maybe i did this, so switched the MBs stock out of the box skin and it has the same reaction.
MB V: 3.6.9202
Thanks. I  don't think it will help, but you could try the latest patch update from my signature below. This assumes you're not using the Windows Store version of MB.
can you send a link to your settings file (help/ support/ view settings)
IndigoFairyX
IndigoFairyX
Was this something to do with my settings or bug in general? Just curious.
