Author Topic: Album year grouping groups everything (0-9)  (Read 248 times)
dash
I've moved to a new PC and moved my MusicBee library over, all fine apart from the group-by year functionality now puts all years in 0-9 instead of separating them by year:
How it worked on the old computer:
I've tried going round the houses a bit with changing the grouping/sorting and changing it back to no avail.  From what I can see, all the settings are identical between both versions.  I've also speculatively rescanned the entire library.
Was previously on 3.5.8447, am now on 3.6.902.
Struggling to figure this one out, can anybody help me?
tjinc
Hi dash and welcome to the forum,
Not seen this before but it probably has something to do with the 'Group by First Letter' option so try this:
   1. Set your 'Group By' setting to 'Album'.
   2. Go back into the 'Group By' menu and uncheck 'Group By First Letter' option.
   3. Reset your 'Group By' setting to 'Year (yyyy)'.
dash
:-* You're a genius tjinc, thank you very much, that resolved it neatly.
