LMS (Logitech/Lyrion Music Server) for Squeezebox devices
profile name:LMS (Logitech/Lyrion Music Server)
user agent:Logitech|iTunes
notes:- tested on a Squeezebox Classic, using LMS 9.1.0
(don't forget to install the 'UPnP/DLNA Media Interface' plugin on LMS)- 'output sample rate' is set to a fixed 44100 rate because when using 'same as source', Opus files play at a lower pitch
- tested with all sorts of audio file types, bit-depths and sample rates without any issues
- music will play respecting ReplayGain loudness values (if ReplayGain is activated in MusicBee)
- gapless playback works
- image size set to 480 since I believe that is the maximum resolution for what Squeezebox devices (that have a display) are capable of
known issues:- when a file needs to be transcoded (e.g. when ReplayGain is on, or when a file type is outside the capabilities of the Squeezebox device, a click will be heard at the beginning of each track
note:Some Squeezebox devices are capable of higher bit depths and sample rates than 16/48.
I was unable to find consistent information for all models, but I think I have a pretty good idea about what they are capable of.
(an LLM that I used to create a table containing the specifications for every model changed its output every single time I asked: "are you sure about that?")It looks like all models are capable of 24-bit. (except for the very first Slim Devices SLIMP3 and SB1 models)
And the Transporter and the Squeezebox Touch are capable of 96 kHz sample rates.
So for this preset I am playing it a bit safe, using conservative settings.
(also, I personally don't care about so-called hi-res audio at all)If you do care about higher sample rates and bit-depths, you could test higher values to see how they work out for your device.
