Author Topic: Syncing to Android WITHOUT Ratings?  (Read 810 times)
shinjibi
Is there a setting in MusicBee that lets me sync to an Android phone without Ratings? I have new music I want to add but am still working through two-way sync issues with the WiFi Sync app, meaning I will lose any ratings I made in GMMP.
kimt1688
Since the rating is exchanged with GMMP using tags, you can disable reverse sync, but Sync without the rating being reflected from the MB side is not possible regardless of whether it is Wired or Wifi.
Please try changing only the rating of the Music file that is already on the device and then Sync. The Music file should appear in the Sync target file.
