Author Topic: Tempo Control Not Remembering Settings  (Read 376 times)
ILeikCityPopMusic
When I have the Tempo Control on and have it set to certain values, it works normally and doesn't reset even when I change songs. The problem is that if I turn the Tempo Control off then back on, the values are reset back to zero, I also reinstalled MusicBee and that still didn't fix the problem. I noticed that when I close MusicBee and reopen it while leaving the Tempo Control on, MusicBee remembers that the Tempo Control is on and enables upon starting it up but doesn't remember the tempo control values?
Since I own the Microsoft Version, it said that MusicBee updated a couple days ago (3/17) with version "3.6.9203 Store" so maybe the new update cause the Tempo Control to not remember the values lol. I'm on Windows 11 if that has anything to do with the problem
This is fixed now, however you will either need to wait until the Store version is updated (not sure when that will be) or install the desktop version of MB and then apply this patch
https://getmusicbee.com/patches/MusicBee36_Patched.zip
