Author Topic: Artist picture retriever  (Read 1558 times)
This plugin retrieves artist pictures from last.fm and wikipedia
https://getmusicbee.com/download/plugins/mb_ArtistPicturePlugin.zip
You will need the the latest patch version or MusicBee RC3+ when it is available
https://getmusicbee.com/patches/MusicBee36_Patched.zip
Happy to hand this plugin over to someone to improve it or maintain it if the websites change their layout
Thanks Steven!  Does it appear as a selectable panel element for right sidebar, like the current "artist picture"?  Or as a full plugin on its own?  Some installation and setup instructions would be appreciated.
Just install the plugin and the pictures from the plugin work in preference to the bind search. There is no UI.
Working great, placing high quality pictures of the artist in the "artist picture" frame element! Using MusicBee 3.6.9198 P, Windows 11 x64.
Question:  can you tell if the picture is from last.fm or wikipedia within the MB interface?
Comment:  the plugin is downloading the original picture as found in its original size--which is the desired action.  In cases where the frame provided cannot display the original size, the picture is cropped to its center and resized to fit the frame, aspect ratio maintained.  Double-clicking within the "artist picture" frame brings it out of the MB GUI in its full size.  Sometimes the original can be quite large, like 1920 X 1080.  Would it be better to resize first to fit the frame, using original aspect ratio, so that the entire image is being displayed there?  The current crop to center action can be kept as an option.
Plugin as default with original image auto-cropped to center to fit display frame:
Double-click opens full downloaded image size (1920 X 1080, reduced here for Forum post)
These pictures are stored as *.dat files in the  ...\AppData\InternalCache\ArtistBackdrops folder.  The cache is not cleared automatically.
Thanks again for this vast improvement on the original Artist Picture element!
Last Edit: March 08, 2025, 10:07:55 PM by sveakul
richard127gm
Wow! Thanks Steven. I couldn't have believed there would be a solution to this so quickly. Been running it for a while and I can't fault it so far. Brilliant.
a2a
Thank you - been using this, too - and it's great  8)
