Author Topic: How can I transfer playlist, rating, and favorite data from album to album  (Read 139 times)
ahhmattc
I want to transfer playlist data from a album to the same album but with a higher quality. I'm gonna replace most of my albums from MP3 to FLAC files but I don't want to go through individual tracks to switch out the tracks from those playlists.  I've tried to search it up on how to do it and I don't think im going anywhere from what Ive seen, most of the posts are saying I have to transfer tags but I don't see any playlist or favorite option. Hope someone can help!
tjinc
As long as you are using MusicBee ver 3.6 there is a simple method to replace a whole album (for example mp3 to flac) that will retain all the original tag data, database data and playlist links:
  1. In your MB library, find the album that you want to replace and select all the tracks.
  2. Right-click > Send To > Folder (Replace) > Replace The Selected Files...
  3. In the browser window that opens, navigate to the new files (i.e. the flac versions) and select all.
VERY IMPORTANT: YOU MUST ENSURE THAT YOU HAVE THE SAME NUMBER OF ORIGINAL AND NEW FILES AND THAT THE TRACKS ARE IN THE SAME ORDER - there are no safety checks here and it will go wrong if either of these is not correct.
  4. Press 'Open', check the confirmation summary displayed and press 'OK'.
That's it: The original files will be replaced with the new ones while retaining the original filename - original files are deleted to the recycle bin.
Obviously you should take the usual back up precautions ahead of trying this.
