Author Topic: Progress Bar High DPI support  (Read 2167 times)
Haste
Hello,
It seems adding a _125, _150, _200 png varient for the volume bar works but not for the progress bar.
I can't find a way for my progress bar to display correctly. It's stretched and blurry rather than pixel perfect.
Would it be possible to add support for this.
can you send me a link to your skin. I might later need the entire skin build folder but just the .xmlc file to start with is ok
Haste
Sure thing. PM sent.
I'll prepare the build folder (It's a bit of a mess and will be clearer once cleaned up)
Haste
i dont see any ProgressButton_125.png or ProgressButton_150.png  file in the set you sent
same with the progress bar itself and the fill images
Haste
Haste
With the new SkinCreator version, it uses the 125 and 150 images but unfortunately it still stretches them.
this stops the unnecessary scaling, but i would expect you scale the height of your images yourself so the layout rules still work which doesnt appear to be the case in the files you sent
https://getmusicbee.com/patches/MusicBee36_Patched.zip
Haste
With the new patch, it seems I can get some part of the progress bar to render correctly but not everything.
Here is what I get for 125% scaling:
That said I'm not sure how exactly I should scale my images.
I played around also with a 16px height for the 100% scale and  20 px height for 125 scale.  (16 x 125% = 20) but that didn't help either.
to keep images and layout rules in proportion you need to scale the 125 images so they are exactly 1.25 times the height of 100% dpi image - the width doesnt matter so much
ProgressBar.png 10x15
ProgressBar_125.png 10x19
what you do with the progress bar image inside that is up to you
having said all that there is a bug where its still rescaling the 125% left and right progress bar images and button, so i need to figure out where its going wrong
this fixes the rescaling issue
you will still need to adjust the proportional size of the images
Haste
It's mostly fixed now. Only just the button is stretched horizontally by an extra pixel:
Top is how the round button renders in MusicBee and below is the source image.
