Author Topic: Errors in Window Title Bar with the "&" symbol  (Read 397 times)
IndigoFairyX
getting this odd error in the title bar when there is an " & " symbol. its being converted to an underscore " _ " such as windows 32bit menus do for for creating short in a menu.
e.g. in AutoHotkey menus syntax this file name would need a double " && " to show a single " & "
menu, musicbee, add, Loren Nerell & Mark Seelig,
would show " Loren Nerell  _Mark Seelig ", as musicbees title bar is showing now.
while
menu, musicbee, add, Loren Nerell && Mark Seelig,
would show " Loren Nerell & Mark Seelig ",  would correctly show a single & with its own escape character
the tag for artist:  Loren Nerell & Mark Seelig
nothing to earth shattering haha, thou i still  grab the window title with autohotkey to search my library with everything so it throws it off a bit.
-xavier
i dont think i can help as MB is setting the correct flag to process the & character, and its not an issue i can reproduce. I am guessing you are using some sort of custom implementation for the windows caption bar
IndigoFairyX
Hmm yeah that could make sense.
I'm using this
https://github.com/Maplespe/DWMBlurGlass
And more so, using winaero tweaker to change the font of the title bar. Segoe UI is bllaah. Thou I do get the & in other window tiltes bars like explore, dopus & everything even on that same file.
