Author Topic: Visualizer crashes in the most latest version  (Read 848 times)
Najmus
I first started the built in visualizer and then when I played my music my app crashed.
I never actually used it So my app never crashed but I wanted to try it but it always crashed,
I downloaded the latest version but it didnot helped
Stating that you're using the "latest version" isn't as helpful as giving us the version numbers.
- What version of MB are you using?
- To clarify, are you using the visualizer plugin, or the visualizer that comes with MB. If the later, which one are you using? If using a plugin, create your bug report on the thread for that plugin so the plugin developer can see it. And include all the info I'm requesting.
- Does MB crash every time you open MB? Or only when you enable the visualizer?
- Are there any entries in the Error Log (Help > Support > View Error Log) from the time you had the crash? If so, copy and paste it here.
- Please post a screenshot of the entire MB window so we can see how you have it set up?
Last Edit: January 25, 2025, 03:56:25 PM by phred
Seedies
I came here with the same issue, my version is 3.6.9202
the visualizer .dll downlaods say mb3 but im using "the latest" release. I put them in the correct program 86 plugin file of mb. Whats the issue?
What specific "visualizer .dll downloads" are you referring to?  Are you selecting the panel element first for "visualiser: graphic" from the panel config menu (button to the left of the Search box) and dragging it to the left side so MB knows where to place the window?  Then, select which one to see and when to start it from the View>Visualiser menu on the toolbar.
