Author Topic: adding flac  (Read 254 times)
Elizabeth
I have some files Buddhist monks chanting. they are flac files. When i try to add them, they do not show up.. I tried individual and a folder. Therevis no error, but they are not in the library.
thank you.
When you try File->Add Files to the Library, choose the files, and click Open, what happens?  Is there a message of any kind?
Have you checked the Inbox as well?  What version number and type of MusicBee are you using?
  • Heal The World
You reckon the chants have got something to do with it, haha?
Don't mind me, I'm just fooling around - had wondered why you'd mentioned this, since I assume you'd have the same problem with any flac file.
They're most likely in the inbox as sveakul mentioned.
Strength and Honour (2025)
