Author Topic: General Sample Code Blocks  (Read 926 times)
  • Heal The World
Might be useful to others. Will post more as time goes by.
Anybody's welcome to add to this thread.
Catering For The Portable Version Or Otherwise
Getting the MusicBee edition:
private string getMusicBeeEdition()
   string appData = mbApi.Setting_GetPersistentStoragePath();
   if(appData.Contains("Roaming") == false) return "Portable";
   else return "Installer or Store";
Getting the Internal Cache folder:
private string getCacheFolder()
   string mbType = getMusicBeeEdition();
   string cacheFolder = "InternalCache";
   if(mbType != "Portable") cacheFolder = @"..\..\Local\MusicBee\InternalCache";
   cacheFolder = Path.Combine(mbApi.Setting_GetPersistentStoragePath(), cacheFolder);
   return cacheFolder;
Skin Overrides For Your Plugin
Loading the skin file:
private string loadSkin()
   string dataFolder = Path.Combine(mbApi.Setting_GetPersistentStoragePath(), "mb_MyPlugin");
   string skinsFolder = Path.Combine(dataFolder, "skins");
   string skin = Path.GetFileNameWithoutExtension(mbApi.Setting_GetSkin());
   string skinPath = Path.Combine(skinsFolder, skin + ".xml");
   if(!File.Exists(skinPath))
      File.WriteAllText
      (   skinPath,
         "<?xml version=\"1.0\" encoding=\"utf-8\"?>\n"
         + "<root>\n" + Environment.NewLine
         + "<element id=\"Element_1\" bg=\"r,g,b\" fg=\"r,g,b\"/>\n"
         + "<element id=\"Element_2\" bg=\"r,g,b\" fg=\"r,g,b\"/>\n"
         + Environment.NewLine + "</root>"
   using (StreamReader reader = File.OpenText(skinPath)) return reader.ReadToEnd();
Querying the contents of the skin:
private color getSkinColour(string element, string attribute)
   string search = "<element id=\"" + element + "\".*?" + attribute + "=\"(.*?)\".*?/>";
   string colour = Regex.Match(loadSkin(), search).Groups[1].Value;
   int r = Int32.Parse(Regex.Replace(colour, @"(\d+),\d+,\d+", "$1"));
   int g = Int32.Parse(Regex.Replace(colour, @"\d+,(\d+),\d+", "$1"));
   int b = Int32.Parse(Regex.Replace(colour, @"\d+,\d+,(\d+)", "$1"));
   return Color.FromArgb(r, g, b);
Last Edit: December 08, 2024, 04:58:58 PM by Mayibongwe
Strength and Honour (2025)
