Hello Mayibongwe, thanks for the reply.
I've attached a couple of screenshots to better illustrate what I'm getting at. In my case, I'm looking to have both album and single covers present, although you could use this for multiple purposes.
https://imgur.com/a/9YQsfYMIn the first screenshot, I'm in theater mode. The main album art is displayed on the left, and the single art is in the panel to the right. Currently, there is no way to make the panel artwork change dynamically as the song changes. If I set it is the primary, it will also change the album art on the left. I think there should be a way to set the artwork in the panel to image 2 and have it stay as that when songs change.
In the second screenshot, two album artworks are shown at the same time in the side panel, one for the album art and one for the single art. Currently, this is not possible at all. Again, They would both change dynamically, with the first album art tracking image 1 and the second tracking image 2.
I hope this clarifies what I mean.
