Author Topic: Player Controls In Bottom Panel Freeze When Moving to Now Playing view  (Read 522 times)
TateB
I tried this with several different skins, and the bug persists across all skins tested.
I normally have player controls in the bottom panel, with the status bar immediately above the player controls.
https://imgur.com/OJ1mIMY
When I move from the normal view to Now Playing in the same tab (using the navigator pane), the player controls and the wave bar at the bottom both freeze.  This is the only element that freezes.  I can use the side panel controls just fine.  If i shift back to normal view, the bottom panel works like normal.
https://imgur.com/0uICAXP
When I toggle the switches on either side of the status bar to open/hide the right and left panels, this causes the frozen bottom panel to permanently disappear.
https://imgur.com/tPYMoiU
can you send a link to your settings file (help/ support/view settings)
if you are using custom tabs or custom views, also send a zip of AppData/Saved Settings and its sub-folders
TateB
Thank you, link sent.
it is a bug that i will look to fix but the reason is you have configured the player controls panel to be hidden in the Now Playing view (the bug is its not actually hiding the panel for some reason).
In the Now Playing view, click the configure layout button by the search box/ Main Player Controls/ Show Panel
