Author Topic: [SOLVED] Visual gaps started appearing in the wave bar.  (Read 1563 times)
mrbenn
Nothing relevant appears in the error log. I tried resizing and moving etc during playback to try and coax messages out of it but nothing.
In the debug version the issue has reverted to its earlier state, so in line with playhead position, etc.
so i updated to the very latest windows version and i now also have the same issue. It might be a case of just waiting for MS to fix whatever is causing it - at this point i dont know of a solution that fully works around the problem
Last Edit: December 05, 2024, 09:11:13 AM by Steven
mrbenn
Yes, that fixed it.
I really appreciate your efforts in resolving this, especially as its clearly nothing to do with MusicBee directly.
Thank you.
Haste
I haven't seen any gap since the latest patch.
I think it's fixed for me too.
Thanks Steven!
