Author Topic: Previously played files outside library folder are re-added when switching PCs  (Read 1034 times)
Gabex
Hi!
I been having this problem for a long time, but never posted about it because I believe it might be very specific to the way I'm using musicbee.
The problem is that previously played files outside my library folder get re-added to the library, but only when I open my instance of MusicBee in a different machine.
Right now I'm using MusicBee as my main player, as a portable application that is synchronized between two Windows machines using MegaSync. I have my music folders in sync as well using MegaSync and using the same folder structure and drive letters. I'm using MusicBee v3.5.8698 P.
I have a few songs and samples in my "Downloads" folder that at some point I played with MusicBee that started to appear in my Inbox even though they are located ouside my Library folder. If I deleted them from my inbox, and then restarted MusicBee on the same machine, they woouldn't pop up again. But once I went to my other machine, they would reappear in my inbox.
Now, I accidentally added everything in my inbox (thinking they were gone) to my library and now they re-appear in my library, again, everytime I switch machines, without even going into my inbox. Everything else in my music folder does go through my Inbox first.
  • Heal The World
Once the files are removed from the inbox, go to Tools > Advanced > Compress Library.
That will erase the deleted entries from the database.
Strength and Honour (2025)
this doesnt sound like a bug. Can you post screenshots of the Library preferences for MB from both machines
Gabex
Thanks, I'll give it a try! I thought that function deleted information about files not in the Library but had nothing to do with the scanning of new files.
Gabex
Yes, here they are.
PC A:
PC B:
Regards
that seems like it could be a bug thats fixed in v3.6 which is available from the top forum topic
Gabex
Hi Steven! Thanks for this amazing piece of software :D
Sorry for my late reply. I tested the latest v3.6 beta and could not reproduce the issue there! So I guess it's fixed now. Would you recommend switching to the beta version? or stay in v3.5?
3.6.x has been available as for more than a year. Many folks are using it and it is extremely stable. I would stay with it if I were you.
