Author Topic: RESOLVED How to delete/remove a library  (Read 579 times)
waynereed
I built a library initially from my 14T peripheral/external drive. E. Made a folder and loaded all of my backing tracks and lrc files into that one folder. Then pointed Musicbee to that E folder. But I'm getting some lag, so I made a new folder on one of my SSD internal drives, D.  Opened Musicbee. Made a new library. But cannot
delete the E library.
PROBLEM is . . . When I add new songs to the D folder, then try to update/scan for added files, in Musicbee, I only have the option to scan the E library! There is
ONE checkbox, next to the E location. And no other option or choice. D does not show up as a scan option.
So any new songs, which aren't in the E drive aren't being found.
I cannot figure out how to delete the E library.  TIA!
Last Edit: November 10, 2024, 10:13:56 AM by waynereed
This scanning issue doesn't sound like a library problem. Can you post a screenshot of where you're seeing that?
To delete an unwanted library, though, just close MusicBee and delete the library files from your drive (*.mbl and related).
waynereed
Doh! I shooda though of that. I didn't want to delete the folder. So I just changed the name of the folder. BINGO!  : )
Sorry, already made the change. Can't make a screen shot not.
Thanks for the tip!
