Author Topic: Import problems  (Read 421 times)
Babydoll32
Hi, I got a problem.
I‘ve some files with # within path and/or filename. Musicbee doesn’t import those files. Am I doing something wrong or have wrong settings?
Example of the full path?
Babydoll32
../MyMusic/#90s Update/#90s Update/1-03 Girl, I Wanna (#90s Update Remix).flac
../MyMusic/#90s Update/#90s Update/1-01 Aicha.flac
../MyMusic/2 Chainz/B.O.A.T.S. II #METIME (Deluxe) (Explicit)/1-18 We Own It (Fast & Furious).flac
Thanks.
I should've asked in my previous reply, but how are you importing the files? Step-by-step, please.
I just created a test file on my desktop, opened MB and dragged the file to the Inbox.  No issues.
Babydoll32
Thanks.
I found out where the error is. I exported Mediamonkey database as iTunes library and imported to Musicbee. Somewhere in XML must be a failure. I let Musicbee rescan directory and now it‘s imported. Thanks Phred!
Glad you figured it out
