Author Topic: MusicBee 3.6  (Read 74392 times)
**** see the last post for the latest update ****
The beta series for v3.6 has started and will be updated with more enhancements over the coming months. See the last post for the most recent download link.
Follow https://twitter.com/MusicBeePlayer or https://bsky.app/profile/musicbeeplayer.bsky.social
for notifications when updates are made available
Last Edit: November 16, 2024, 12:53:32 AM by Steven
https://www.dropbox.com/scl/fi/9yannc5kewf98xxx01a7c/MusicBee_Setup_3_6_9065.zip?rlkey=wwmhuwi9gln95ls0x7mpw28b6&st=qthf6fej&dl=1
backup
https://mega.nz/file/80kF2arT#hX56bJFijU8Sd7eMEAnApHKS6h1oQtWh0VwEx_sULV8
this is an incremental update and includes all changes since version 3.5 - unzip (to the music folder MusicBee is installed for portable versions) and then run MusicBee_Setup_3_6_9065.exe
1. Tag Inspector supports creation of the cuesheet
2. Consistency in the trimming of jpg pictures
3. Accuracy in Bing artwork searching
4. File Converter: Allow more than 9 max threads
5. Sorting a date in the column browser
6. Extra definitions for "Quality" tag
7. Added hotkey commands to select tabs 1..9
8. Tag Inspector: Multi-selection support for the delete function
9. Touchups on the Highlighting Rules
10. Better handling of MusicBee not restarting when a VST plugin was (is?) active
11. Pitch/ Tempo and Sample Rate controls can be docked to a sidebar
12. Added "Stop after Current" to the notification tray menu
13. MB will now prompt for the artist bio to be saved when a new artist starts playing or MB is exited without saving
14. "Edit: Insert Timestamp for Synchronized Lyrics" hotkey now works in the Tag Editor
15. Music Explorer will remember the selected artist
16. Better handling of plugin uninstallations
17. Shuffle Playlist through Command Line
18. Disconnected the main and floating windows so they are independent
19. Support for Send To/ Folder (Replace) to replace multiple files in one go
20. Prompt for Confirmation When Closing While Music is Playing
21. Added Original Year for sorting
22. Clicking on a track in the top tracks panel will open the album and select the track
23. Date sorting is supported for date-typed fields
24. Along the lines of: Allow "Suggested Genres" to look for Track Artist if Album Artist is "Various Artists"'
25. Enable in-table editing of the track number on the auto-tagger dialog box
26. Larger Album artwork in the Thumbnail Browser
27. Volume Analysis: Parallel execution for multiple files
28: Bug Fixed: Playlist Mixer: "Any Field" Null problem
29: Bug Fixed: Crossfading + Volume Normalization (AIMP)
30: Bug Fixed: when referencing aggregate functions in $Or, $And
31: Bug Fixed: MB loses references to the main song in ASX files
32: Bug Fixed: Hotkey for 'configure custom/virtual tags' can open multiple panels.
33: Additional (four) Custom Tags
34: Added support for finding rather than filtering in the main panel search
35: Re: Bug When Syncing Playlists Containing ASX Files
36: Update to highlighting rules behaviour
37: Added chapter list support
38: Bug Fixed: Error when clicking a button in the Music Explorer
39: Clicking on a multivalue artist tag now links to the first artist in the Music Explorer
40: Bug Fixed: Custom weblinks toolbar bug
41: Bug Fixed: Compact mode error clicking settings
42: Excluded PDF files from being moved when 'move non-media files' is unticked
43: Allows adjustment of the Music Explorer top tracks panel widthBug Fixed: Main Panel Not Refreshed When Switching From Folder Browser To Music Node
44: Graphics glitch fixed and "MusicBee" menu button alignment improved
45: Bug Fixed: 'Move files' warning recurring many times
46: MusicBee API: Support for function overloading
47: Bug Fixed: Populating the Track duration in ASX files
48: Drop Down List When Editing Tags in the Main Panel
49: Goto Text Search Box hotkey updated to toggle between focusing the text box and the track list
50: Added ContrastBoost support for synched lyrics
51: Mouse wheel used to seek forward & backward through the playing track
52: Autofill values in the <publisher> tag
53: Bug Fixed: Double-clicking on a track triggers inconsistent actions
54: Bug Fxed: Start Playlist From Last Track Played Bug
55: Bug Fixed: Inconsistent Alignment Behaviour in the Track Info Panel
56: ContrastBoost support for the non-highlighted portion of synced lyrics
57: Bug Fixed: Problem With ID3V2 Track Count Field
58: Music Explorer: Option to show/hide artist statistics
59: Smooth Fade When Skipping
60: Trank Info Panel: Skinning Elements
61: Plugin support for raw sample data
62: Plugin support for VU meters
translator file - updated new.txt file (this file is only used by translators and not required for the MusicBee application update):
https://getmusicbee.com/patches/new3.6.txt
Last Edit: February 09, 2025, 04:51:05 AM by Steven
https://www.dropbox.com/scl/fi/o2a10ozri5i4grejxhrfg/MusicBee_Setup_3_6_9108.zip?rlkey=4idiifbu5kh5cl4facfl5rctb&st=tvnd15pa&dl=1
backup
https://mega.nz/file/k9llhD7C#9_I-8IV6y2SeYufFVg3SCfT2CYLwuV9p0BhNj7QVUm8
this is an incremental update and includes all changes since version 3.5 - unzip (to the music folder MusicBee is installed for portable versions) and then run MusicBee_Setup_3_6_9108.exe
- Locked playlists are now set as read-only files, and have a visual lock indicator
- support for re-ordering custom tags in the tag editor
- support for docking visual plugins (such as the VU meter) in some 'Now Playing' views
- address issues retrieving iTunes artwork
- various bug fixes
Last Edit: February 09, 2025, 04:51:22 AM by Steven
https://www.dropbox.com/scl/fi/xk5q642rpkugbjri6nqnu/MusicBee_Setup_3_6_9156.zip?rlkey=0mw3hpkh88tw3imd2ibskvjea&st=zpcpqpd7&dl=1
backup
https://mega.nz/file/8xsWTYhB#5MEx-TdkWhtfXWkPwqkwXXwbovr4ux_fvauxtO0ZDaA
this is an incremental update and includes all changes since version 3.5 - unzip (to the music folder MusicBee is installed for portable versions) and then run MusicBee_Setup_3_6_9156.exe
- Custom sorting for many fields including virtual tags and custom tags
- enhancements to support some new plugins
- various bug fixes
Last Edit: March 01, 2025, 09:21:30 PM by Steven
