Here I go again...
I have set up a test PC and copied over my portable version of MB, changing the paths where necessary. At first VUMeter 2.5.1 wasn't showing in the panel. The panel was completely blank. No context menu on right-click. No nothing. I tried with 2.6 and same thing. Finally realized I had forgotten to change the path to the VUMeter skins. Now when MB launches, the panel is black and before I can right-click it, MB throws an error. It won't let me copy the error message and immediately closes when I click OK. I was able to get the error message from the log. If I remove the plugin .dll, MB starts and works as expected.
MusicBee v3.6.9101.34338P (Win10.0), 6 Dec 2024 16:32:
System.OverflowException: Value was either too large or too small for an Int32.
at System.Convert.ToInt32(Double value)
at MusicBeePlugin.VUMeter.SetPivotOffset()
at MusicBeePlugin.VUMeter.FillVertexArrays()
at MusicBeePlugin.VUMeter.Window_SizeChanged(Object sender, SizeChangedEventArgs e)
at System.Windows.SizeChangedEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e)
at System.Windows.FrameworkElement.OnRenderSizeChanged(SizeChangedInfo sizeInfo)
at System.Windows.ContextLayoutManager.fireSizeChangedEvents()
at System.Windows.ContextLayoutManager.UpdateLayout()
at System.Windows.UIElement.UpdateLayout()
at System.Windows.Interop.HwndSource.Process_WM_SIZE(UIElement rootUIElement, IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam)
at System.Windows.Interop.HwndSource.LayoutFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.CallWindowProc(IntPtr wndProc, IntPtr hWnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.HwndSubclass.DefWndProcWrapper(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
