Author Topic: Device Settings always Prefixing some paths with predefined strings.  (Read 736 times)
farrukh
I'm started observing this  Bug in versions 3.5.8698 and 3.5.8698 P.  I never tried this in previous versions. \
I am using built-in functions in order to create the same folder structure on the portable device as it is on my source drive. However, whenever I add the function for  different type of media, it always prefixed it back to its default strings. Even if I update it via Edit --> Preferences dialog or directly with Device Settings, the problem persists.
Adding the function:
And whenever I get back to my device settings, it become like this:
Regarding the use of functions, I already discussed this in the following topic and got it working properly.
Failed with functions to get the dir structure to sync on portable device
But now, I'm facing above defined bug.
Any workaround or correction?
Am I missing something or doing wrong?
Please guide.
Thanks
Last Edit: September 02, 2024, 05:16:53 PM by farrukh
farrukh
I tried to update C:\Users\Farrukh\AppData\Roaming\MusicBee\MusicBee3Settings.ini, as per this screen shot:
But when I started MusicBee, it was still showing the same issue as discussed in the Parent post of this Updated Reply.
However, the MuscBeen3Settings.ini never changed.
So, I'm wondering from where it is Prefixing the strings "Audiobooks, Podcasts and Video"
