Author Topic: Can't Transfer Music  (Read 689 times)
Jason
1.  I loaded all music into  musicbee app
2. Plugged in a new MP3 player
3. MP3 player shows as D:\ drive
4. Musicbee recognizes device
5. All music shows under sync preview
6, When I hit SYNC, i get an error window that sates "the storage folder D:\Music\ no longer exists and may be changed in the device sync preferences"
7. I uninstalled Itunes just in case this was an issue
8. MP# player is an Aiworth model MB08. I do not see an option to change any sync preferences on the device
9. Any suggestions are appreciated
Thanks
Should be posted in this forum: https://getmusicbee.com/forum/index.php?board=4.0
Numerous threads there touch on your issue, search them first.
Last Edit: August 09, 2024, 07:27:32 PM by sveakul
Are you doing a wired (USB) sync or a WiFi sync?
  • Heal The World
Does this folder already exist to begin with? D:\Music\
If not, then you first have to create it before you can start the syncing.
Strength and Honour (2025)
