Author Topic: Files with album names of only one letter cannot be synchronized.  (Read 799 times)
skywhite
When connecting devices and synchronizing all songs, only files with a single letter in the album name cannot be synchronized properly, resulting in an error.
The error statement is as follows
“Copy Failed - Error HRESULT E_FAIL returned from COM component call.”
I would like to know how to solve this problem.
Thank you in advance.
The following is the original Japanese text of the above
デバイスを接続して全曲を同期する際、アルバム名が1文字のファイルだけが正しく同期できず、エラーになる。
エラー文は以下の通りです。
「Copy Failed - Error HRESULT E_FAIL returned from COM component call." というエラーです。
この問題を解決する方法を知りたいです。
よろしくお願いします。
Last Edit: July 29, 2024, 05:33:46 AM by skywhite
What version of MB are you using? (Help > About) INCLUDE THE LETTER (if any) AFTER THE NUMBER
How are you syncing? (Wired, WiFi)
skywhite
Version is “3.5.8447 Store"
Installed in Store
Wired synchronization
hanks. Given that you're using the Store version, not much can be done. Even if it is a bug. Updates to the Store version are only issued when a new (full) release is published.
I suggest downloaded and "installing" the Portable version. Place it in a new folder called C:\MusicBee (or something else to your liking.) You can keep the Store version installed until you have the Portable version set up the way you want. Once you're happy with the set up, you can remove the Store version. You could install the Installer version instead of the Portable, but most seasoned MB users use the Portable. Both the Portable and Installer get frequent patch updates.
Grab the v3.5 Portable or Installer version from the first forum topic. Once you've got it in place, come back here and download the latest 3.6 patch from my signature below. Unzip it and copy the files to where you placed MB and let it overwrite the existing files. You'll now be on the latest version.
