Author Topic: PlayerInfoCentered doesn't function on multiple lines  (Read 956 times)
<element id="PlayerInfoCentered">false</element>
works when a single track line is displayed, but doesn't when multiple lines is selected
there are a couple of other settings that might impact this, so could you send me the skin
You can use the Sample Skin to check it.
The behavior was intentional for multi-line display. For the next update, so as not to affect other skins, to disable centering in all cases, you will need to explicitly set <element id="PlayerInfoCentered">false</element>
edit:
i think i will leave it as is because it affects other major skins
Last Edit: July 14, 2024, 05:43:33 AM by Steven
edit:
Fair enough. Most skinners that will want this function will use it for their bitmapped skins, and for those, "PlayerInfoCentered">false works fine for multiline.
It just seemed inconsistent to me that it didn't function for non-bitmapped skins.
