Author Topic: Does not show covers  (Read 295 times)
paolopuntop
Music Bee in the album list (however ordered) gives a "cover missing" message and does not show the cover.
The file "Folder.jpg" is present in the folder.
If you choose try "edit" the album or choose "show cover" the cover is displayed correctly.
See image   https://drive.google.com/drive/folders/1i0ILi_TbAb69EuOJ8CiFQ6lcs6ZJC6wQ?usp=sharing
Is there a way to solve it?
Thank you
Last Edit: July 12, 2024, 12:11:38 PM by psychoadept
I edited your post to expose the image link. Directly displaying an image from Google Drive is difficult.
Thank you
Be sure MB knows where the cover is:
1.  Go to Prefs/Tags(1)/artwork/set which pictures are displayed, and hit the "Edit List" button
2.  In the "Album Artwork Retrieval Filter" window that comes up, check "Folder.jpg" and move it to the top of the list using the up/down arrows (image reflects my own settings, change to match yours).
3.  Hit the button in the lower left corner "Rescan Artwork;" when it finishes restart MB.
